How to fix wind deflector?
Old Jan 18, 2009 | 09:46 AM
Captain_Liu's Avatar
Default How to fix wind deflector?
Hi, my S is a MY00, and it doesnt come with the wind deflector, i'm thinking to buy
one, but not sure how to fit it? Anyone got any experience or any good way to do
it?
Cheers,
Allen
Old Jan 18, 2009 | 11:49 AM
loftust's Avatar
You'll need to buy an OEM wind deflector. You'll also need to drill two holes in the secret compartment lid to allow the bolts to fit through, securing the deflector hinge mechanism.
This is how mine fits (although I have my larger, DIY wind blocker, the stock one is shorter):
http://i336.photobucket.com/albums/n...t/DSC02082.jpg
You should be able to see the two small silver bolts at the bottom of the hinge, these secure it.
Old Jan 18, 2009 | 01:25 PM
NineBolts's Avatar
Captain, Are you asking because you've seen the one in the FS section.
You should be able to fit the standard deflector to the compartment lid.
Old Jan 18, 2009 | 01:55 PM
Well, I always wanted to get a deflector, but dunno how to install it as there is no
hole on the lid, not sure where exactly should I drill the hole and how big the hole
has to be.
Old Jan 18, 2009 | 02:34 PM
NineBolts's Avatar
From what I've read on here, in the early years the deflector was an option and then later became standard.
there may be some hole positions marked on the underside of the lid, they may be underneath a fuzzy covering.
There are threads on fitting the screen.
Old Jan 19, 2009 | 12:42 AM
loftust's Avatar
Lift the lid of the secret compartment. You should see two recesses (possibly under the fuzzy covering) for the small nuts (8mm, IIRC) that secure the bolts I mentioned above.
number7
Dec 20, 2011 11:21 AM
joefish1298
Jun 9, 2009 04:43 PM
Rafael
May 30, 2008 11:54 AM
energetic
Feb 8, 2005 02:42 AM
4373
Jul 21, 2001 12:27 PM
