import limiter
Old Sep 12, 2010 | 03:20 AM
andy s2k's Avatar
Default import limiter
whilest replacing my starter button i found a little black box,it was cable tie to the loom.It's the converter from kph to mph as my car is a import but it still has the limiter on it, there are some simple wiring instructions on te back of the box,all the wire's are ired into the loom apart from 1 a yellow wire which on the back of the box it says "YEL Limiter out) its just been cut short and taped to another wire. does anybody know if that should be connected and if so where and would it take the limmiter off ??? thanks andy.
Old Sep 12, 2010 | 08:09 AM
Ultra_Nexus's Avatar
So your car is limited to about 120mph?
Can you select between mph and kph on your speedo?
Old Sep 12, 2010 | 09:45 AM
Squeak's Avatar
loftust says:
Converting the clock I/P signal and removing the limiter can be a tedious affair. There are units up for grabs from a Southampton company on eBay that achieve both.
FWIW, I put UK clocks in mine, and fitted an Apexi RSM
Old Sep 12, 2010 | 10:04 AM
Dembo's Avatar
I have two. One for the speedo, and one for the ECU (that does the limiting). The simplest way to de-limit would be to interrupt the speed sensor signal going into the ECU in the passenger footwell and connect it to a second speed converter. That way you're limited to 180mph, not 180kph, which isn't generally a problem.
Fitting UK clocks would solve the speedo problem, but you'd still be limited because of the JDM ECU. And I think fitting a UK ECU creates a nightmare of alarm problems.
Not sure why there'd be a "limiter out" wire on your converter; perhaps that's for other other cars.
Old Sep 12, 2010 | 10:35 AM
andy s2k's Avatar
the clocks are in mph not kph i tried wiring it to the wire's for speed in and speed out thats on the box and nothing happened then whilest on a very long straight road (coff somewhere) just up plugged it which ment i didnt have a speedo that didnt work either and it also ment i had no PAS so iv just wired it back to how it was and left it lol
Old Sep 12, 2010 | 10:47 AM
Dembo's Avatar
Does that make any sense to anybody else? Or is it just me?
Does your speedo read mph, or does it like mine, read m/h with the k disconnected?
Old Sep 12, 2010 | 11:57 PM
Heinz '57's Avatar
And breath
Old Sep 13, 2010 | 01:35 AM
andy s2k's Avatar
sorry did it on my phone, it reads mph
Old Mar 11, 2011 | 12:09 PM
Juicy Steve's Avatar
Originally Posted by Squeak
loftust says:
Out of interest how much does that cost? I plan to drive to france a back a few times as the folks there live so k/ph would come in handy, and my oddometer is still in km's and I'd like that number to be roughly 0.6 times smaller. Plus the importer has just dabbed the k out on the current dash and it bothers me.
Old Mar 11, 2011 | 01:01 PM
leftfootbraking's Avatar
I bought a HKS SLD from Evasive for my JDM S2K. It has removed the speed limiter from the ECU, but the clocks still stop at 180kmph.
