indicator bulbs
Old Jan 12, 2012 | 10:49 AM
s2konroids's Avatar
Default indicator bulbs
Grrrrhh!
Just replaced all the rear lights but the left indicator refuses to work resulting in failed indicator light, tbh I can't see what the hell is wrong! The other side is fine!
Anyone any ideas, it was working before.
You would have thought this was a simply task!
Cheers
Old Jan 12, 2012 | 11:14 AM
GaryB's Avatar
You mean you've replaced the rear light units or just the bulbs?
Using all the known working bulbs, plug the old unit back in as a first test and work methodically from there.
Old Jan 12, 2012 | 11:23 AM
martin j's Avatar
Try swapping bulbs side to side, that'll prove something.
Old Jan 12, 2012 | 12:09 PM
s2konroids's Avatar
Ground pin was bent ever so slightly on the side, it wasn't immediately obvious at first
Old Jan 12, 2012 | 12:31 PM
martin j's Avatar
Never mind, sorted, best result and at little cost.
martin j
May 30, 2016 12:45 PM
2000BBS2k
16
Apr 28, 2014 12:03 AM
stfutexas
Jul 14, 2009 11:46 PM
a3lkx
Dec 1, 2007 04:06 AM
LostWaffle
Nov 3, 2004 11:56 AM
