Interior Light Sensor
Nope, quite sortable yourself if you're even a little bit proficient with a couple of tools
You can pull back the rubber over the trigger and go from there. Should be easy to remove and replace.
Yep, as said above , but I'll elaborate a bit - unscrew the single screw and you'll find a highly complex switch (bit of metal and a spring) get some contact cleaner or light emery paper on it and you can clean it back into working full time again
Took me ages to actually find mine - I was looking in the door jamb - kicked myself when I found it :facepalm:
