ITB's
Old Oct 7, 2010 | 08:53 AM
oxhouser's Avatar
Default ITB's
just a heads up there is a set of weber ITB's and programable ECU on a well known auction site, nothing to do with me or anybody i know
its sitting at £300 with 2 days to go
you would need a manifold and a couple of sensors plus the know how
Old Oct 7, 2010 | 09:14 AM
Dixon Motorsports's Avatar
Need to wire in the TPS and Air temp sensor, it really depends on how good the programable ECU is, if its an AEM or K-Pro then you shouldn't have a problem to get them setup correctly.
Old Oct 7, 2010 | 09:15 AM
The Loon's Avatar
If it a Mugen N1 ECU which is non programmable, I assume your stuffed?
Old Oct 7, 2010 | 10:09 AM
MB's Avatar
MB
Member
Yep, stuffed.
Mophead's Avatar
Does ITB's mean independent throttle bodies? And what are the advantages of these over a single throttle body and air filter?
Old Oct 7, 2010 | 10:10 AM
Jayboy83's Avatar
tried looking, couldnt find anyhing
Old Oct 7, 2010 | 10:12 AM
punchdrunk's Avatar
Originally Posted by Mophead,Oct 7 2010, 06:09 PM
Does ITB's mean individual throttle bodies? And what are the advantages of these over a single throttle body and air filter?
Fixed
Old Oct 7, 2010 | 10:13 AM
MB's Avatar
MB
Member
Individual throttle bodies.
They can make more power / torque depending on what you select. In a lot of cases adding them alone isn't that effective. I don't think the intake on the S2000 is too strangled tbh.
There are a lot of side issues to consider though. Filtration, trumpet length, noise, etc.
Old Oct 8, 2010 | 03:14 AM
oxhouser's Avatar
its a webcon fully programable ecu from Weber
try searching for weber throtle body or weber Alpha throttle body
£310 at the mo but i expect it to go higher this stuff is quite expensive new
Old Oct 8, 2010 | 10:54 AM
rtbiscuit's Avatar
just for the noise, i love ITB's
