J's racing 2.2L stroker kit
Old May 22, 2006 | 12:41 AM
Chris Type R's Avatar
Default J's racing 2.2L stroker kit
J's Racing 2.2L stroker kit upgrades the F20C engine to 2200cc displacement. Compression ratio will be raised to 11.8:1. The entire engine kit has been balanced. Recommended to use J's Racing SPL 2.2L ECU or other market tuning device.
Price: CAD $1,930.00 (USD $1,619.67)
http://www.aj-racing.com/catalog/product.p...1&cat=91&page=1
Is this an upgrade for 1997cc engines to 2200cc ? Same rev. limit, etc ?
Old May 22, 2006 | 12:43 AM
Taikyu's Avatar
Banned
You will loose 500 rpm peak power
should gain about 30 odd Ps
Torque!
Anthony
Old May 22, 2006 | 12:44 AM
Taikyu's Avatar
Banned
Oh and the Block will require Machining
Anthony
Old May 22, 2006 | 12:48 AM
energetic's Avatar
J's Racing uses the JDM Honda 2.2lt stoker kit for their race S2000...
OEM JDM!
Old May 22, 2006 | 12:52 AM
aldfort's Avatar
Higher compression will mean you need to be more careful on fuel choice as well. When you add the cost of the ECU or at least a re-map it's not a cheap mod. Nice though
Old May 22, 2006 | 12:56 AM
Been reading up a little more - it seems like it'd be an expensive upgrade - probably cheaper to get a JDM 2.2.
Old May 22, 2006 | 01:01 AM
Neil.H's Avatar
You will obviously need a full engine rebuild to fit it =
Paper Lawyer's Avatar
Or a different final drive
Oh, and there isn't a JDM 2.2?? (unless there is for 2006?)
Old May 22, 2006 | 01:02 AM
[QUOTE=Paper Lawyer,May 22 2006, 10:01 AM] Or a different final drive
Old May 22, 2006 | 01:07 AM
Neil.H's Avatar
Yep the Jap 06 has the 2.2l engine, there's no option for the 2.0l.
