Josh's s2k build thread
#71
Another thing ... the dust shields had to be removed . Can anyone see a issue with this at all ? Should i put some heat reflective tape over the rubber joints on the suspension ?
#72
No issues ditching the dust shields, I got rid of mine a few years ago (front and back), I have protected the ball joint rubbers though
Bodyboarder1981 (04-30-2017)
#73
#74
Hi Josh, I used some high temp bandage and some stainless cable ties.. I am out at the moment but fairly sure I got a pic or two will check later when home.
#75
#76
Thanks man appreciate it
pretty much what I done yesterday to mine ... used exhaust heat wrap ( same as yours by the looks of it ) I'll do the other side today
#77
New wheels on
For a cheap set of wheels I'm pleased with them . Put the standard size tyres to see how much room I have . Looks like I'll be able to run 225/255 set up .
edit -
forgot I weighed the standards and the rota's .
Standard front -8.3kg rear - 9.5kg
rotas front 8.4kg rear 8.5kg
obviously weighed with out tyres .
edit -
#78
Looks good
The heat shield actually does fit with those callipers but you need to do some cutting to it.
Furthermore double check the pad overhang on the discs as I know there was an issue with the adapter on these.
#79
pad overhang? As in the pads overhanging the edge of the outer part of the disc?
