Rear arches
Old 05-02-2017, 01:23 PM
calisfar's Avatar
Default Rear arches
So... After spending many months (over a year) trying to find someone within a reasonable distance to take on the job, 4 places just didn't get back with a quote (including Westgate Classics that did most of car sos) and one that just said no to my face, the car is now finally in the body shop. I knew it was bad, but WOW !
Drivers side (externally the "good side") now in progress
Second hand donor part had already started to go but not to the same extent. Shot blasted and repaired
initial fitting of inner arch now in place.
More pics and updates to follow as I get them.
Old 05-03-2017, 06:38 AM
Toms1989's Avatar
Wow. Inner arches have taken a beating!
Fair play for sticking up the pictures! gives others an idea on what to expect with these arches!
Old 05-03-2017, 07:25 AM
nomadicS2k's Avatar
If that's not an advert to get the arches rust treated and protected....I don't know what is!
Old 05-03-2017, 02:12 PM
calisfar's Avatar
Sure is. It eats from the inside out, if you can see it it's already a world of pain.
Outer skin now in place
A bit more finishing to go but soon we will see what the passenger side (worst externally) is like :worried:
Old 05-04-2017, 12:29 AM
Define198's Avatar
is their any way to spray any stuff into the arch so it gets the inside of the top lip to stop any rust forming? without drilling a hole?
Old 05-04-2017, 01:42 AM
Irish TuneR's Avatar
Long hose type thing from the boot...
Old 05-04-2017, 02:03 AM
Define198's Avatar
will take a look when i get my car back from the body shop and see if i can spray in some bilt hamber ub
Old 05-04-2017, 09:13 AM
Nick Graves's Avatar
A LOT of Bilt Hamber...
The problem is, one can never really seal those welds properly without galvanic-dipping the shell, so there is always a danger of the tinworm re-appearing.
Old 05-04-2017, 10:20 AM
Nottm_S2's Avatar
It'll see off a lot of S2000s the old tin worm
serious work there
Old 05-04-2017, 11:41 AM
calisfar's Avatar
I had a Porsche 924 before the S2000 which my son now has. 33 years old and no rust as Porsche galvanised the entire body.
Passenger side now started and as predicted its worse
Quick Reply: Rear arches
