Keyless Entry
Old Jun 9, 2016 | 10:57 AM
Snakecharmer's Avatar
Originally Posted by Mike RT4
Just checked with my local Honda dealers and the Keyless entry module for MY2005-2009 cars is 38380 S2A G11. However, it has been discontinued. None on eBay at present.
Rob,
How did you narrow it down to this part?
There's loads in the USA. The bracket is different because it fits on the other side of the car, but you only need the innards.
http://www.ebay.co.uk/itm/01-Honda-S...UAAOSwu1VW7iGX
Old Jun 10, 2016 | 12:31 AM
Mike RT4's Avatar
Not same part number though, so would prefer to get one that is the same to be sure. I've already tried loads of things that haven't worked so far, so am loathe to keep throwing money at things that "might" work....
Old Jun 12, 2016 | 04:05 AM
Talk to Bob at Modifry Products.
My link
http://www.modifry.com/index.php?rou...tegory&path=18
Old Jun 12, 2016 | 01:21 PM
Boof!
http://www.ebay.co.u...=p2045573.m1684
http://www.ebay.co.uk/itm/1821314649....N36.S1.R1.TR5
Old Jun 13, 2016 | 12:36 AM
Mike RT4's Avatar
None of those are a G11 for a UK MY2005
Old Jul 21, 2016 | 10:48 AM
Dear Forum, after all of my positive and hopefully correct diagnostic I am afraid to say that the problem I had with door locking had still persisted. As did my occasional alarm going off issue.
HOWEVER! I now think that I have eradicated both of these niggling problems. Here's why. After reading a blog from another owner regarding the Thatcham Cat 1 alarm I decided to follow
the instructions to diagnose the last fault code. ( Ignition ON press lock button followed by indent button 3 times ) red light shows the entry circuit problem where the fault lies. In my case the bonnet. (hood) 3 flashes.
The switch under the bonnet is like the one on your fridge; you never really know if the light has gone off. Well, my light was not going off! I had already cleaned and lubricated the switch to no avail and also
put a velcro pad under the bonnet where I thought the button was in contact with the bonnet without any success. THEN, I modified my switch and made the contact button longer. Bingo. So far and a week later no alarm going off, doors locking like they should. The picture here will explain how I did it. https://www.flickr.c...eposted-public/
Old Jul 22, 2016 | 01:40 AM
Mike RT4's Avatar
What do you mean by "indent" button?
Have you got the link to the aforementioned blog?
Old Jul 22, 2016 | 12:16 PM
Page 2. http://www.s2kuk.com/technical/honda-alarm.pdf
Your welcome!
Old Jul 23, 2016 | 01:54 AM
Nick Graves's Avatar
Yeah, I had that corroded-bonnet-switch thing on my old Prelude; repaired the contacts with some solder.
Old Oct 11, 2016 | 01:22 PM
Finally discovered the problem to my intermittent door locking failure using the remote fob.
Under the dash (on my car) drivers side and taped onto the plastic molding there is a plastic box which contains the Hamilton Palmer keyless entry module.
This is in addition to the unit located under the drivers seat. There is no connector to the circuit board and the wires to the unit are soldered directly onto
the board. This unit bypasses the Honda keyless entry module. I knew this was the problem as soon as I had it in my hand because by disturbing the unit it
suddenly began to work while it was in my hand and I could feel and hear the two relays on the board clicking.
This led me to believe that it was either, one or both of the relays which were failing, or, there was a soldered joint gone dry where the wires attach to the PCB
The easiest and cheapest option was to first re-soften the solder at each wire connection before removing and testing the relays. I did this six weeks ago and
have used the car daily for both long and short runs and the doors have locked every time and seemingly with more of a positive and immediate response to the
remote fob.
The unit on my car was easy to drop down to access but I believe some may have been located behind the kick panel at the side.
https://www.flickr.com/photos/338430...posted-public/ Myhttps://www.flickr.com/photos/33843082@N08/30175357691/in/dateposted-public/ link
