Leaks everywhere! Update
Old Jan 17, 2007 | 06:12 AM
wampa's Avatar
Default Leaks everywhere! Update
Iam now getting pead off, Just cant stop it!!!
I dont remember these leaks or wet patches before I put the hardtop on
NO 1 Leak!!!
No 2 Leak
Old Jan 17, 2007 | 06:51 AM
MunkeyBoy's Avatar
Remember to lock the cat out of the car at night.
Old Jan 17, 2007 | 06:52 AM
Si@Hendy Performance's Avatar
UK Trader
With most cars this usually is due to blocked holes that drain water - thus sending the water through the bulkhead:
Have a look under the bonnet Mark, pull the black plastic trim off thats near the windscreen wipers - it really does just pull off! Then in the corners by the wings there maybe a huge pile of wet leaves blocking the drain holes. Clear the leaves out and voila!
Old Jan 17, 2007 | 06:53 AM
wampa's Avatar
Help Iam drowning!!!
Old Jan 17, 2007 | 06:55 AM
UK Trader
Your carpets could do with a vacuum at the same time!
EDIT: do you or Kirsty park it under a tree? - Tis Autummn/Winter and believe it or not those leaves fall off!
Old Jan 17, 2007 | 07:03 AM
wampa's Avatar
I have just pulled the black cover up there is water just sitting there.
Need to take the windscreen wipers off to get into it and as it is rainging now and nearly dark I will investigate tommrrow
if I havent drowned!!
Old Jan 17, 2007 | 07:13 AM
LTB's Avatar
LTB
In your first post when you said you were getting peed off, I hope you're getting out of the car before doing the peeing.
This could be the cause of your problem.
Old Jan 17, 2007 | 01:10 PM
AquilaEagle's Avatar
Administrator
Is it leaking up from below?
You need to find where the water is coming in.
Sit in the car and get kirsty to hose it
Old Jan 18, 2007 | 12:24 AM
MunkeyBoy's Avatar
Golden shower.
Old Jan 18, 2007 | 04:17 AM
gaddafi's Avatar
Banned
it's the hardtop
it didn't leak before did it?
