Leaving the S Garaged for 4 months
Right as per title I'm Out the country for 4 months, so the S will be sitting in the garage.
I'm going to have it serviced before I go (3 months early). Unfortuanatly I do not have power in the garage so no battery conditioner can be used. So should I disconect the battery or not?
Anything else I should do?
- Park in a garage
- Leave handbrake OFF
- Get car on axle stand
- Disconnect battery
- Make sure you are low on petrol in the tank (some say petrol do goes off if not used)
- Car cover
- Pump the tyres to a higher psi (maybe 35psi?)
- Car cover
Up on axle stands, handbrake off.
Battery up to you - a trade off between the alarm being available vs the battery dying.
Or... Get a trusted oppo to "exercise" it for you once a fortnight (but still no handbrake).
I use an OptiMate charger (Clicky) rather than disconnecting the battery. It cycles the battery to mimic normal usage, so is actually better for the battery than disconnecting it; and allows the alarm to still be used.
I have however, seen a solar powered battery condition... probably just a crappy gimmick though tbh.
Originally Posted by jakesalter,Mar 19 2009, 12:29 PM
Which would be great if the OP had power to his garage!
Oops, good point, well made
Fill it to the brim. Stops moisture/condensation forming in the fuel tank.
