Leccy Windows
When power is removed from the car. Does this throw the auto up/down feature??
My auto windows has stppoed working? Is there a procedure for it to re-learn this feature?
What happening with mine is that it will auto wind down but when it goes up it goes all the way to the top then winds itself back down half way.
Any one experience this? I thought by trying to get it to re-learn it would sort it
From the FAQ
Auto Window Function Fails
When your battery is disconnected, the auto function on the drivers window can stop working, this is because it then needs to be reset.
The car has to be started!!
1. push and and hold the window button down all the way until its completly down.
2. when its completely down, let go and push it down again and hold for 2 to 3 seconds. then let go
3. now pull and roll the window up until its all the way up.
4. when its up let go
5. pull the button up again for 2 to 3 seconds.
(after step 2, he said you should be able to hear or feel the motor or something inside reset.)
6. now then your autoscroll should work correctly.
If you've done this already and you still have a problem then its not a common fault.
