Looking for some help.....
Old Oct 27, 2009 | 03:26 AM
jonner's Avatar
Originally Posted by mikey k,Oct 27 2009, 12:16 PM
Simples
You will have 18mm more clearance on the the inside edge of the wheel = a good thing!
You will 8mm less clearance on the outside edge = possible rubbing = rolling of arch, high camber, not lowering it etc
Sorry bout this....
So i good for stock suspension then.....????
Old Oct 27, 2009 | 03:29 AM
mikey k's Avatar
Measure the gap between the outer edge of your stock tyre and the inner edge of the wing
BTW is that front or rear you posted?
Old Oct 27, 2009 | 03:48 AM
jonner's Avatar
I just read the offset calculator a bit closer.....i put both sizes in....nevere put the current size in.....
Old Oct 27, 2009 | 04:01 AM
mikey k's Avatar
Old Oct 27, 2009 | 04:21 AM
jonner's Avatar
Let me try again....
Going from the faq sizing of the oem 16" wheels
Front...
Current 16 x 6.5 +55
New 17 x 7 +42
Inner Clearance: 7mm MORE
Outer Position: EXTEND an extra 19mm
Rear...
Current 16 x 7.5 +65
New 17 x 8 +47
Inner Clearance: 12mm MORE
Outer Position: EXTEND an extra 24mm
Old Oct 27, 2009 | 04:55 AM
mikey k's Avatar
Waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay too low on offset then
Old Oct 27, 2009 | 05:06 AM
jonner's Avatar
Any recommedations on offsets.....???
Old Oct 27, 2009 | 05:52 AM
mikey k's Avatar
As per PM's but for everyone else
These work very well even at 30mm drop
Front-17x7.5 ET+50, Rear-17x9.0 ET+63
Front-215/45ZR17, Rear-255/40ZR17
Old Oct 28, 2009 | 07:01 AM
jonner's Avatar
Cheers for the help Mikey....
jamesnffc
Oct 9, 2011 11:19 AM
JayMMWen
Mar 2, 2010 01:43 PM
jonner
Oct 28, 2009 07:38 AM
MuckaLun
Mar 11, 2007 11:31 PM
jdm s2k
Jan 3, 2006 08:41 AM
