Lowering Engine Compression
Old Mar 14, 2011 | 12:40 PM
stu_c's Avatar
Default Lowering Engine Compression
Hi all
after getting my S2k turbocharged I have started to notice that my oil dipstick has poped up a few times and spraying oil onto the engine in my eyes it seems like the oil pressure is getting too high.
I thought about replacing the piston rings but as the engine will be apart so I might as well put low compression pistons in and replace the Gasket seal
I have looked at CP Pistons which seem very good for the price but wondered what you recommend?
Old Mar 14, 2011 | 12:49 PM
RobinA3's Avatar
Your dip stick popping out is not due to high oil pressure, it seems to me that you are getting positive crankcase pressure which is not good, either your breather system is blocked (the crankcase pressure should always be negative) or your rings have worn which then allows cylinder pressure to get past into the crankcase.
I'd do a leakage and compression test first which will show up any piston ring problems.
Old Mar 14, 2011 | 12:58 PM
MB's Avatar
MB
Member
Stu, turn it round the other way, it works, trust me
And can I have my Prodrives back please?!
Old Mar 14, 2011 | 01:00 PM
MB's Avatar
MB
Member
Is your engine breather still connected to the intake? That wouldn't be good.
Old Mar 14, 2011 | 01:02 PM
Kitesurfer s2000's Avatar
Do a search its a common problem people have i just cant remember the answer.
Old Mar 14, 2011 | 01:03 PM
razzele's Avatar
Have you got crankvents or a catch can?
Old Mar 14, 2011 | 01:10 PM
stu_c's Avatar
Just thinking if I lower the compression with pistons and gasket be much better for her :-(
Old Mar 14, 2011 | 01:11 PM
stu_c's Avatar
Catch can mate
Old Mar 14, 2011 | 01:15 PM
Not needed with the greddy kit have you hybrid the tubo yet, t620z it pulls so much better to redline. PS what psi are you at.
Old Mar 14, 2011 | 01:18 PM
razzele's Avatar
ah ok-
I think now there is actually a FRM liner friendly piston set available that will lower your compression. From what i have read, you really shouldnt need/want that with a Greddy turbo kit.
