lowering question
Old Mar 27, 2010 | 05:08 AM
andy s2k's Avatar
Default lowering question
hi i've purchased a set of lowering springs off a mate and he was telling me i need drive shaft spacers,i hadn't got a clue what he was on about so i thought i'd ask the people that know, you guys on here thanks andy
Old Mar 27, 2010 | 05:17 AM
andy s2k's Avatar
oh if it helps i'm only lowering the car by 30mm
Old Mar 27, 2010 | 07:13 AM
mattyc's Avatar
You don't need spacers mate. Unless you get vibration from your inboard cv joints. If you do then fit them and it should go. Read up on adjustable toe arms and steering rack spacers. You definately will need your geometry resetting if you do fit your springs
Old Mar 27, 2010 | 12:13 PM
andy s2k's Avatar
thank you for the info
Old Mar 27, 2010 | 12:41 PM
ruffryders_sohaib's Avatar
30mm you should be ok
Old Mar 27, 2010 | 01:13 PM
Wobbly's Avatar
Some good info in HERE
Old Mar 27, 2010 | 03:32 PM
m1bjr's Avatar
FWIW its not the inboard CV joints that play up, but the roller bearings and the splined 'buckets' as some call them.
These are the 3" or so diameter 'solid' looking metal tubes with a ring of bolts around the face, near the differential.
They are inboard of the inner CV boots.
Go without spacers, you most likely wont need them.
Mclovin54
Feb 6, 2016 02:56 PM
Fontal
Feb 19, 2011 06:23 AM
JEEBS
Jul 15, 2010 02:00 AM
baldy2007
16
Apr 24, 2009 12:58 PM
fwd-sukz
Jul 5, 2007 04:53 PM
