MAP Sensor screws / Result of replacing MAF
Old Jul 16, 2014 | 10:01 AM
RichwiththeS2000's Avatar
Default MAP Sensor screws / Result of replacing MAF
Went to remove the screws holding in the MAP sensor today as I have a replacement, as soon as you put the slightest twisting pressure on the heads get mashed up. God damnit.
I guess they need drilling out and replacing but does anyone know what screws they are? So annoying - the easiest jobs always end up the biggest pain!
Old Jul 16, 2014 | 10:03 AM
s2konroids's Avatar
They certainly are, map sensor btw maf airflow map sensor manifold pressure.
Old Jul 16, 2014 | 10:05 AM
Well spotted -edited! Cheers :]
Nick Graves's Avatar
In future, use a Vessel JIS screwdriver - what looks like a Phillips head isn't & you've far less chance of mullering it with the correct bit.
Info
Old Jul 16, 2014 | 10:09 AM
richmc's Avatar
Info
But why do Honda have to use plasticene screws?
Old Jul 16, 2014 | 10:15 AM
The bit I had was fully in there, literally just the slightest twist and it started to garble it up. Arf. Oh well - found a nice diagram here;
http://estore.honda.com/honda/parts/...=&b=E++01&dl=#
Old Jul 16, 2014 | 10:17 AM
So what the heck is a "screw-washer (4x16)" translated into something useful? ha
Old Jul 16, 2014 | 11:51 PM
richmc's Avatar
That will be a screw with integrated washer, metric size 4mm x 16mm long. It's perfectly clear, you can't translate it into anything more useful as that is exactly what it is.
Old Jul 17, 2014 | 07:05 AM
Originally Posted by richmc
Info
I think it's the steel/ally corrosion issues 90%. I remember hanging my full weight off the screwdriver before they'd crack.
I had it with the NSX's headlamp covers & now one is dremelled into a slot-head!
And that was with an impact driver, which was a tad scary on a headlamp pod.
Old Jul 17, 2014 | 10:41 AM
Managed to get the screws out tonight by smashing a flathead into the top with a hammer!
The really good news is after a test drive my low speed kangerooing is gone. Pulling away feels like a normal car now, the heatsoak effect I was seeing before seems gone. Pulls great throughout the range. This was with an ebay MAF sensor, £100 jobby. If it holds up it will have been well worth it!
I also sprayed a small amount of carb cleaner into the MAF hole and reset the ECU
