Is it me or is the search broken?
Struggling to bleed coolant and I know there are a few threads but I get no results.
Front end jacked up high, heater on but not getting the air out of the bleed valve near the rocker cover.
Gary, by far the easiest method i have used in the past IMO, is put your mouth around the rad cap opening, attach a transparent long tube (2-3 mm diameter IIRC) onto the bleed nipple (which is opened slightly) near the block and blow into the rad cap whilst holding the tube - eventually, well rather quickly you will see bubbles appear.
By the far the quickest and easiest method, just dont ingest the coolant LOL.
ryanswhites2k
Apr 26, 2013 03:18 AM
