Meguiars Hyper wash
Old Aug 11, 2008 | 11:38 PM
Survey S2000's Avatar
Default Meguiars Hyper wash
Having recent decided to buy some quality kit clean my car, i purchased some hyperwash from Serious Performance, to realise on receipt that the stuff is a foam cleaner!!
What i wanted to know is if the wash can be used with the good old bucket and sponge method.
Ive had a look around the web and it seems you need a pressure washer and a lance of some description. Both of which i never intended to buy!
Also brought some clay bar but seems i may need some liquid spray to lub up to. Is this right??
Couldnt find tangos tread so i apolyogise for posting here in advance!!
Old Aug 11, 2008 | 11:45 PM
Pie_n_Chips's Avatar
Cant see why not, as long as you dilute it, as per instruction - The Megs has a dilution rate of 400:1
Buy a foam lance - I have, its great fun
Clay bar - yes you can either use it on a wet car or use a lube - MEgs quick detail is my choice, but there are plenty of alternatives.
Have a look here for all the products you'll ever need and then some
Old Aug 12, 2008 | 12:00 AM
NigelC's Avatar
Regarding the clay lube. I was talking with a Meg's rep at a car event a couple of weeks ago. Apparently, the Ultimate Quick detailer (in the BLACK spray container) is unsuitable. You should use the Quick detailer (in the RED container).
Old Aug 12, 2008 | 12:02 AM
Boab01's Avatar
Hyper wash is a good shampoo
Buy some quick detailer to lube your car as you clay it.
Old Aug 12, 2008 | 12:13 AM
Hey pie!
THey do look fun!! The missus wants an apple mac though and im not sure if i can strech to it.... do you know any good sites for what is needed.... please bear in mind im simple.
Thank all for your help!
So guys is it black or red....
Old Aug 12, 2008 | 12:15 AM
Boab01's Avatar
Have you got a pressure washer?
Old Aug 12, 2008 | 12:26 AM
Yes i have.... if my dad hasnt filed it under B1N. I'll have to pay the folks a visit.
Its old now and dont know if it will work though? it had a pipe that was mean to be placed in soap i think... will that work as a lance?
Old Aug 12, 2008 | 12:28 AM
Stookystar's Avatar
Red!
Never knew they did a black one but I always buy the Megs Quick Clay complete with Quick Detailer in the red container.
Never had a problem yet!
HTH
Old Aug 12, 2008 | 12:29 AM
Boab01's Avatar
No, what you need to do is find out if it works, then take a picture of the connector end of the removable lance bit and then post it up .
I will then tell you if that is compatible with a foam lance and what bits you need.
If on the other hand it's not then you need to buy another pressure washer, i can also suggest to you what you need.
Old Aug 12, 2008 | 12:37 AM
johnbuck's Avatar
Hey pie!
I use Hyperwash as a shampoo, great product and last for ages as it's very concentrated.
Visit www.detailingworld.co.uk for more than enough info on everything.
There are also a couple of threads on here re detailing where there will be some good info if you trawl through.
