Milage Question
Originally Posted by s2000tim,Oct 19 2009, 06:18 AM
Mine died at 107k
Smoke? Rod escape? Did it start to knock?
Would be good to compile a list symptoms from engine failures so we can get a picture of why they fail at 100k+.
Originally Posted by buaan,Oct 19 2009, 02:14 PM
If I do it I'll get the block dipped, decked if needs be, and rehoned to OEM spec.
I thought it was not possible.
Isn't the national average on a family/work car meant to be 9K-12K?
I think with a car like the S you should be more concerned on service history and condition then mileage then look at mileage. Depends whether you want a car to cruise around on a summer day in or a car to thrash around all over the shop.
Originally Posted by Si2k,Oct 19 2009, 06:58 AM
Can you rehone the FRM cylinder of the S2000?
60deg cross hatch pattern the same as many other honda engines.
Page 184 of the Honda S2000 00-03 service manual if you are interested
Shame about the knocking/cylinder scoring s2000Tim
If the engines are throwing rods it is probably due to worn bearings yes?
A badly scored liner will require a rebore and a rehone plus oversized rings.
Although that's pretty standard, I am not sure what the FRM does to the mix and whether or not the consensus is to simply get new liners.
