MoT Failure
Indeed.
It may have sufficient holding force but is on its last ratchet - right up as high as it goes.
So if you have to park on a steep hill you could't pull it on any harder - thats the issue.
Sounds like you need to adjust it up at the lever - cant recall if the S has that adjustment?
Or the cogs/gears in the rear calipers are not taking up the slack correctly (winding out).
How was rear brake performance?
I think that's when the level can be pulled all the way to its max without it locking the brake enough.
I had mine MOT'd the other week and watched them they put it on rollers (with grips) and yank the handle on and off whilst monitoring a gauge.
Calipers etc alright, cable tight?
I think the MOT handbook says that cars with an LSD should not be tested on the brake roller.
It might be ok with a Torsen???
Maybe someone with better knowledge will chime in.
Chris.
Edit:
http://www.motuk.co.uk/manual_370.htm
Chris.
Edit:
Cheers Chris,
FFS bloody amateurs, i might have a word with them? but they'll just claim 'we didnt know your car had LSD'.
I take it doing this method can somehow f@#k the LSD?
