Muz window protector
Hopefully will get a new plastic rear screen soon (see separate thread for details!).
Got to thinking maybe I should get something to try and minimise creasing etc. of the new screen once installed.
Only product I am aware of is the window roll protector from Muz........basically a rubber tube that you put into the external fold of the screen as the roof goes back to prevent folding/creasing.
Anyone got one and if so what's the verdict?. If it works well then may consider getting one. Bit of a faff having to get out of car to put tube in place before completely lowering roof but if it offers a real benefit then prepared to put up with the hassle!.
I have one of these.
It came with the car when I bought it, along with a Muz well mat for the rear window.
I seems to do a reasonable job. It doesn't entirely eliminate creasing from the rear screen, but is definately an improvement from having nothing there.
I did read somewhere that you could just throw an old towel across the rear screen if you wish to save money, but I have no idea if it works or not.
Sort of on topic - just got some of the BMW rear window cleaner stuff. Just done mine and very impressed with it, fairly cheap too at 7 quid a throw
Originally Posted by cuzza,Nov 11 2004, 04:06 PM
what does it look like - would a length of that pipe lagging stuff not do as good a job - the long polystyrene stuff with a cut in it for fitting over pipes?? Just a thought
Have to agree with the BMW window cleaner (Part number is 81 22 9 407 665 ) it is the best product of its type.
to BMW - never thought I'd do that
I have even recommended it to a colleague with an MGF
BMW one is the way to go! Fantastic stuff! I also think it may help the flexibility of the plastic and stop it shattering
Use it inside and out!
I made my own roof mat and tube both covered in suede. I have binned the tube - too much hassle every time the roof goes up or down! Especially if it starts raining! Storing is a pain as well!
I just try to keep it clean & warm! (and the roof!
Use it inside and out!I made my own roof mat and tube both covered in suede. I have binned the tube - too much hassle every time the roof goes up or down! Especially if it starts raining! Storing is a pain as well!
Originally Posted by Neil,Nov 11 2004, 05:24 PM
Not sure.......might do. Think the Muz tube is covered in a soft velour type material to avoid marking the plastic. Not sure what the polystyrene tube would be like in this respect. Guess ultimately it might be possible to knock up a DIY version?
Pete
