My first service
That is corrosion, some one has scraped the top of it to expsoe it further though!
That's refurbable no problem.
Only thing is you may struggle to get a colour match to the others it is often best to do them all!
Problem is there is nothing wrong with the other three. More than 1 being a problem and I'd probably use it as an excuse to start saving for some 17s.
To the touch it feels like the lacquer's missing - and the striations leading away from each "hole" would reinforce that idea.
That assumes that debris grit blasts the leading edge and nothing else could have touched the face of the wheel
The problem has been made worse by some one scratching at them, causing the lines and exposing more area to air.
