My S2000 is leaking!
Old Nov 3, 2008 | 06:41 AM
  #21
tomkbucks's Avatar
Originally Posted by Bibbs,Nov 3 2008, 07:36 AM
I had some leaks on my new roof when fitted. The window doesn't fit snug against the rubber.
You can peel the rubber off and then adjust where the clips sit (about 5mm of play) and then replace the rubber.
You can also adjust the angle of the window by taking the door card off.
I've done both and it's sorted now.
is there a guide to either of these? they are both worth a go !
Old Nov 3, 2008 | 06:48 AM
  #22
Bibbs's Avatar
Nope!
Open the roof half way.
The rubber just pulls off, you'll need a flat bladed screw driver to push them back in.
The only one different is the, bottom one is screwed in at the bottom (you can still peel the top off though).
Each rubber part its in a ally holder with 3 screws holding it to the roof. The holes are elongated so you can loosten them, and move them out, and re-tighten them.
The door card is easy. There is then a bolt (12mm or 14mm I think) that adjusts where the window mount and brush sits. You can then move the angle.
It's all fairly obvious once you do it.
I'm not mechanic and it was a doddle (like fitting a supercharger, swapping an engine and swapping the roof).
Old Nov 3, 2008 | 08:28 AM
  #23
veilsidejonnyo's Avatar
Originally Posted by pistonbroke,Nov 3 2008, 07:33 AM
Who did your roof for you, ?
I'd take it back to them.
It had been fitted before I bought it 6 months ago from MrBrightside31.
He wouldn't have noticed cause he always had the hardtop on.
No receipts for the replacement unfortunatley.
I'll have a look at what Bibbs has mentioned and see if I can effect it in anyway, otherwise I'd be open to offers of help/advice as to where to take it for adjustments.
Old Nov 3, 2008 | 09:21 AM
  #24
AquilaEagle's Avatar
Administrator
I must do this, been leaking for a bit now on both sides.
Bibbs did you replace the rubber or just give it a good greasing?
Old Nov 3, 2008 | 10:55 AM
  #25
tomkbucks's Avatar
ok plan of action
remove the rubber seals on the leaking side
grease them up ( while off the car ! )
adjust the window tightin tothe seals
replace and make sure its all nice and tight
Old Nov 3, 2008 | 11:05 AM
  #26
Sounds like a plan matey!!
I'm gonna have a go this weekend providing it's not p1ssing down (as per every other weekend when I try and work outdoors!)
Will report back with progress and hopefully a conclusion.
Old Nov 3, 2008 | 11:20 AM
  #27
Bibbs's Avatar
i replaced the roof, and used the original rubbers.
The roof was supplied without the rubber or the ally clips. So i needed to transfer them over.
Old Nov 3, 2008 | 02:16 PM
  #28
s2konroids's Avatar
Sometimes you just have to replace the roof.
I had tried everything in the past then when i replaced the roof the problems disapeared
Old Nov 3, 2008 | 02:22 PM
  #29
lovegroova's Avatar
Did you get it done at Carhood warehouse? If so, how much was it in all?
Old Nov 3, 2008 | 02:30 PM
  #30
s2konroids's Avatar
No carhoodwarehouse is to far for me over 5 hours!!.
I did however get the roof for them (plastic one), but only paid 100pound for fitting from a guy in preston who i have used in the past.
490 all in
