My S2000 plan
Old Mar 20, 2008 | 08:26 AM
chilled's Avatar
Default My S2000 plan
Finally made a decision to keep the S. My plan is to run it at track days, and to fix the suspension.
I've already ordered ARB's front and rear which leaves me with:
Nitron track shocks with eibach springs, or KW V3 or Bilstein PSS9
anti-bump steer kit
front brakes ducting
what else do i need? I'm not going to lower the car much. But am I going to need a steering rack spacer?
I still need the car to be road usable.
I may baffle the sump too. But may just keep the oil topped up.
Old Mar 20, 2008 | 08:32 AM
MB's Avatar
MB
Member
Good news Mr Chilled.
Well, you prob know what the billies drive like. Don't think many have experience with the KW's over here, and there is a Nitron club so you will get some decent reviews there. Think only one of them goes on track?
I think with your tyres as sump would be useful.
Other than that a fit and forget brake solution might be good - Tarox under the OEM wheels?
I'd ditch the rear exhaust for somehting light. The weight is incredible.
Old Mar 20, 2008 | 08:47 AM
chilled's Avatar
I'd happily ditch the exhaust if I could guarantee it was no louder than stock. It's more important that I don't get black flagged than make a noise. The weight saving would be nice though.
Old Mar 20, 2008 | 09:12 AM
motogp1's Avatar
Good choice mark.
It will be interesting to see the results of your mods on track.
Old Mar 20, 2008 | 10:08 AM
AquilaEagle's Avatar
Administrator
tbh not many aftermarket exhausts get black flagged You could get something made I suppose
Old Mar 20, 2008 | 10:35 AM
j8mie's Avatar
[QUOTE=AquilaEagle,Mar 20 2008, 06:08 PM] tbh not many aftermarket exhausts get black flagged
Old Mar 20, 2008 | 11:29 AM
mikey k's Avatar
Two actually
Oulton twice and Donnington once.
Chilled - just watch the ride height on the front if you go to Nitron Track
Mine is 35mm lower and it knocks the rebound adjuster on the lower arm
It also knock the side of the reservoir on the splined wheel for the ABS sensor on full lock.
I could probably prevent with an ARB or stiffer setting but I like the way it handles now!
Old Mar 20, 2008 | 11:52 AM
RedUn's Avatar
I can vouch for the V3's being good, Chris Franklin seemed impressed with them also
No knocking either
What about a Mugen exhaust?
Old Mar 20, 2008 | 02:07 PM
chilled's Avatar
Really not convinced on the whole exhaust thing.
I don't want to lower the car too much. I'm more after making it stiffer.
Old Mar 20, 2008 | 02:15 PM
mikey k's Avatar
Exhaust thing is a double edged sword. Most the really light weight ones are also very noisey!
Both PL and PJL have been black flagged for noise IIRC
The Nitrons will probably give you the best damping vs unsprung weight.
MeisterR
UK & Ireland Traders Forum
Sep 12, 2017 12:13 PM
surfer_crx
Feb 23, 2014 12:55 PM
naim43
Dec 27, 2007 04:10 AM
Aze85
Feb 20, 2006 11:18 AM
offroadr35
Jan 14, 2004 08:51 PM
