No vtec
After driving AE's car mine seemed a bit sluggish and I didn't notice such a difference when reaching 6000rpm.
Dad took the car for a spintoday and seems to think the cars overall acceleration is better than his
but agrees that there is no great difference at 6000rpm
After doing a search it looks like people are suggesting MAP sensor.
Please can people throw ideas at me and explain what the MAP sensor is
Thanks in advance
but agrees that there is no great difference at 6000rpmAfter doing a search it looks like people are suggesting MAP sensor.
Thanks in advance
Try the old give it a tap and see if that helps it works for others, check the connection is all clean and tight.
They do fail quite alot, new one from htg
http://www.hardtopguy.com/store/product.ph...5&cat=53&page=2
Do a search lots of info on here .
It 'might' not be anything electrical/mechanically related.
I take it your comparing and MY02 with an MY09?
Could they have changed the fueling on the later cars, hence less/more of a kick at vtec?
Do you mean the kick when vtec engages?
The ECU maps on all four of the Eagle family cars are different.
Budgies Silver = mk1 with pronouced vtec kick
Yours = mk2 less kick
Seniors = mk3 even smoother
Lily = mk5 DBW
If it wasn't coming in you would know it!
There would be a big difference.
You could try disconnecting the vtec solenoid to prove it one way or the other
Lily = mk5 DBW
Lily = mk5 DBW
Lily = mk5 DBW
when changing an oil filter.
