deleted headlight washers
So as I mentioned in The Loon's thread about deleting the headlight washers. After somebody reversed into my car, rather than replacing the damaged washer I decided to delete both of them for a cleaner look. I also took the opportunity to fit a replica lip I've had lying about since last summer What do you all think?
Before
[attachment=39320:IMG_0255.JPG]
[attachment=39321:IMG_0256.JPG]
[attachment=39322:IMG_0257.JPG]
After
[attachment=39323:IMG_0564.JPG]
[attachment=39324:IMG_0565.JPG]
[attachment=39325:IMG_0566.JPG]
[attachment=39326:IMG_0567.JPG]
Before
After
Very nice! Really freshens up the front end.
Definitely something on my list, but would need to do this at the same time
Clear Indicators
Clear Indicators
Agreed, going to get mine smoothed and number plate brick removed I think. Then maybe get a smaller US style plate and see if I can blag it.
When you look at a clean front end compared to a standard UK front its quite apparent how bad the plate ruins things!
I don't mind the plate, just the brick. So I've had the washers and the outer number plate holes filled in and shaved about 2.5cm off each end of the number plate and it looks really good, I've not taken a pic yet but will when I get a chance and post it up.
I'm not a massive fan of the smoothing absolutely everything; removal of badges, number plates, washers, holes, etc - I think it ends up looking a bit naked tbh
Having said that I really don't miss the ugly afterthought headlight washers !
