OIL again
Old Aug 3, 2004 | 05:47 AM
NAP1's Avatar
Default OIL again
I did a search on oil and have no idea about the info I found out - even more confused.
I also know this is semi covered in the Tech FAQ's but only refers to the mineral oil. Is it OK to use 10W40 Shell Helix (fully synth).
Also say for example a friend of a friend of a friend had put a drop of semi synth 10W30 in the car (not much maybe 250ml) would that casue some serious probs???
Believe it or not I am not technically minded and have never really had to top up previous cars and just need a straight answer so I know I am not destrying my car.
Old Aug 3, 2004 | 06:11 AM
PSC's Avatar
PSC
Firstly It is safe, but not necessarily advisable to mix oils from different manufacturers/grades, unless explicitly advised against.
The viscosity grades hold true for both Synthetic and "vanilla" (non synthetic oil).
So stick to the grades advised where possible.
0W and 5W are effectively the same grade (cold temp) except for the pour point difference.
-- Paul
*Edit* - Your 10W40 should be fine.
Old Aug 3, 2004 | 06:19 AM
NAP1's Avatar
Cheers Paul,
If I now changed to 10W30 after topping up with 10W40 for a couple of months would that be bad???
Should I wait for an oil change at the next service???
Old Aug 3, 2004 | 06:30 AM
PSC's Avatar
PSC
I can't see it as been detrimental, however I would (personally) chose a grade and stick to it.
-- Paul
jaxxx
Sep 8, 2010 04:41 AM
Lord-Jaffa
Nov 26, 2009 06:08 AM
Bobba
Nov 16, 2007 06:36 AM
chinba82
South Florida
Jan 9, 2007 08:14 PM
1black_lude
Oct 26, 2006 08:13 AM
