oil cooler install
not sure on pressure drop but if you consider its all done in 1/2" tube and the majority of the oil ways in the block are a fraction of that it should not be a problem
the oil gauge shows 85 PSI on cold idle and 20PSI on hot engine idle (oil at 90 degree) and thats taken after the cooler
all the parts i bought from Merlin go to their web shop and select oil systems
the olny manufacturer of th 4 port sandwich plate is Greddy it probably costs more than the
20 psi hot is about right!
I have a three port Greddy maybe I can "adapt" that to four
Or move the pressure sensor to the OEM oil pressure switch location to free up a port. (AEM EMS will make OEM switch redundant
)I can get hoses made easily so I guess all I really need is the cooler!
