One for the electrical / loom experts
This connector is located down in the driver footwell on a '99 UK car behind the trim panel by the accelerator pedal.
Under normal cicumstances, what is it connected to?
Sorry I cant help but have a free bump!
It looks not too dissimilar to the large grey connector that is connected to the ecu in the passenger footwell.
If you lay with you back flat in the driver footwell (its a squeeze) you might be able to see up into the dash and figure its origins
Alternatively its something to do with the Honda fitted H&P Alarm system?
Pretty sure that is the plug for the driver side loom. Connects the loom to the main harness inside? Ive just fitted all my looms yesterday on a 2000 model and pretty sure that was one of them. Other than that it could be the keyless entry module plug. Connects to a small black box.
Yeah I think it's the main rear loom which runs down under the scuff plate - maybe things like CD auto changer, fuel sender, fuel pump relay antenna, seatbelt sensors, brake lights, roof motors - not sure how many of those it takes care of or what you'd miss in a track car though.
No, no at all.
The looms had already been stripped back to the bare necessities in about June.
Literally I couldn't find the counterpart bastard connector and it was causing the old girl not to fire.
It was just err... hiding.
He would have lost...
Drivers seat belt switch,
drivers door open switch,
right convertible top motor,
seat belt tensioner switch,
drivers rear ABS,
12v socket,
boot opener swtich,
fuel tank pump and level sensor,
passenger door open switch,
passenger seatbelt tensioner,
left convertible top motor,
hardtop defogger,
passenger rear ABS,
fuel pressure sensor,
passenger rear light cluster,
number plate lights,
fog light,
driver side rear light cluster.
Might have missed some but as you can tell I'm very bored at work!
drivers rear ABS,
12v socket,
boot opener swtich,
hardtop defogger,
passenger rear ABS,
fog light,
drivers rear ABS,
12v socket,
boot opener swtich,
hardtop defogger,
passenger rear ABS,
fog light,
drivers rear ABS,
12v socket,
boot opener swtich,
hardtop defogger,
passenger rear ABS,
fog light,
Good point Noodles!
EDIT** - Added more I can think of
drivers rear ABS,
12v socket,
boot opener swtich,
hardtop defogger,
passenger rear ABS,
EDIT** Boot lock switch,
EDIT** Boot brake light,
fog light,
drivers rear ABS,
12v socket,
boot opener swtich,
hardtop defogger,
passenger rear ABS,
fog light,
