Oooopppss Had A Lil Spin
Originally Posted by UK_S2000,Sep 12 2007, 12:32 PM
Nice wheel mangle!
Sounds like yah well on the way to being back on the road though!
The diff flange is connected to the half shaft by six bolts - no possibility of play there. On the basis you can clearly see the diff flange is not moving it sounds like you need to check the connection between the half shaft and the hub (which I've not fiddled with, I'm afraid).
Whoops; sorry to see this - hope you get it sorted OK.
Any insight into how you got into the spin?
It's surprising how many prangs are shown on here that haven't involved a third party - which is good, obviously, because the event of spinning into someone else wouldn't be healthy for your driving license!
Sounds like the balls have fallen out of your Rzeppa joint, but I think you said the hub' ends the good end?
Sorry, I mean the tripode joint if it is the inner end that's got the play. You've usually got three wheels with needle rollers in them & they can fall out.
