origin b2
Old Apr 18, 2005 | 09:49 AM
ian winter's Avatar
Default origin b2
hey people
is anyone else unable to update their origin b2? i keep getting the error message
cannot connect to update server - please check internet connection
any ideas?
Old Apr 18, 2005 | 10:07 AM
mikerich's Avatar
Had this.
If you have one of these little plugs connected to the PC - check the brass coloured connectors. If they are out of line - gently persuade them back.
Be careful - they are fragile!
Old Apr 18, 2005 | 10:08 AM
Fieldl's Avatar
This happens to me occasionally. The update software isn't the best in the world.
Did you update the software a few months back ?
When it happens I just retry later.....
Normally works after a bit.
Old Apr 18, 2005 | 10:12 AM
Paper Lawyer's Avatar
I have that every time now - always works if I close down the Origin software and then load it up again.
Old Apr 18, 2005 | 10:15 AM
P 1's Avatar
P 1
Might be this.
Here's the email from Origin in January this year, with a link for the software update:
Dear Customer
Last week we informed you that we are about to
release an important upgrade to the Origin Update
utility, to accommodate some changes being implemented
by some ISPs (Internet Service Providers).
We are pleased to announce that the new upgrade is
now available for download.
DO I HAVE TO UPGRADE?
Yes, after 17th January all Origin b2 users downloading
via a PC will need to have the new software installed.
WHAT IF I USE A MODEM TO UPDATE MY UNIT?
If you use the modem supplied with the unit instead of a PC
you are not affected by this upgrade you DO NOT need to do
anything. Please continue as usual. However, if in future
you want to update via a PC then you will need to download
and install the new software first.
CAN I USE THIS SOFTWARE ON A MAC?
No, the software is Microsoft Windows compatible only.
(However, Mac software will be arriving soon.)
HOW DO I DOWNLOAD THE NEW SOFTWARE?
The new upgrade is now available for download via the
members' section of origin b2 web site at:
http://www.originb2.com/memberslogin.cfm
When you have logged into the member's area please click
'software updates' on the left-hand menu and download
the file 'b2-setup'. This file will be in .zip format.
Once downloaded, extract the .zip file and run the
'OiupdV133_setup.exe' file.
Once the file has run you will be prompted to 'Modify,
Repair, Remove', select the option for 'modify',
continue until the 'finish' button is displayed,
then select 'finish'.
Your Origin b2 will then be ready to update.
Many Thanks
Customer Services
Origin Technologies Ltd
Old Apr 18, 2005 | 11:01 AM
AquilaEagle's Avatar
Administrator
New updater program should do it - firewall problem with older one or something
Old Apr 18, 2005 | 11:19 AM
ian winter's Avatar
thanks for the input
did the software update even taken the whole lot off and started again
tried the gentle persuasion thing but that has not worked either.
i run norton internet security and have telewest bluyonder broadband if this helps.
it has not worked since friday
thanks
Old Apr 18, 2005 | 01:20 PM
P 1's Avatar
P 1
Ian
Since the updated software hasn't helped, have you tried a different COM port in the software interface? Mine uses COM1, but your PC might have assigned a different one.
Have you looked in device Manager (start > settings > control panel > system > hardware > device manager) to see if there's a problem with your COM port?
Have you tried file > initialise remote in the Origin updater utility?
Sorry - clutching at straws here, but this is what I'd try.
If this failed, I'd be contacting Origin.
HTH.
Old Apr 18, 2005 | 03:04 PM
Fieldl's Avatar
Has the update ever worked since Norton was on the machine ???
Norton is a PITA for blocking outbound ports and not asking.
Old Apr 19, 2005 | 06:32 AM
ian winter's Avatar
turns out it was because i updated the driver on my webstar usb cable modem?
thanks for all the suggestions
