Oxygen Sensor
Hi all,
Had my car in at Honda yesterday after the engine diagnostic light came on. They checked it out and said i needed a new Oxygen sensor. They have oredered it and will fit in under warranty so no problems there.
Just wondered what this sensor does? Not a tech head so thought i would ask if anyone else knows?
Thanks,
Simon.
Thanks,
Simon.
Hi Simon,
It tells the car's engine management how your fuelling is working, and tells it how much fuel to put in.
It's screwed into your exhaust manifold.
They fail quite commonly after 30-50k miles.
That explains it then, car has just done 29,000 miles, so a bit low for a fail but hey ho. At least the warranty is covering it! Would that explain an increase in fuel consumption? As i was thinking it was drinking a little bit more than usual!?
Yep, you will use a lot more fuel. Normally about 40 miles less to a tank.
When they fail, they send a signal to the ECU that the fuel mixture is lean, when it really isnt, so the ECU puts a lot more fuel in to compensate.
It can also make your idle unstable and the car may have tried to cut out.
Cheeky question, any idea how much they are? Honda or motor factors.
Are we talking the o2 sensor just before the CAT? I might do mine if its not too expensive and see what the mpg returns are.
Atleast you got it sorted under warranty, thats a good shout
honda will ask you for £154/7 for it , ive just changed the MAP and O2 for high fuel use but ive only covered about 80 miles so far cos ive hurt my poor little back
so will tell all a little later if it has improved the mpg, i bought a bosch replacment from eurospares for £60 not the cheapest but
