P0122
Old Jan 9, 2008 | 12:03 PM
Armand's Avatar
Default P0122
Ok, i have managed to get the fault code from my baby and its reading
P0122 - Throttle Position (TP) Sensor Circuit Low Input
I have done a search but no definitive answer about fixing the problem has been written.
some background:
As with most of use, i have been driving around slower than usual (and i need new rears), average vtecing certainly no hammering it through the gears.
Got home with no problem and the car was stood for 20 mins before i went out again to move it.
Straight away the CEL light came on and i have just diagnosed it as P0122.
Several days ago the car had a slight 'shudder' @ 4k rpm in 6th which i thought nothing of, it certainly didnt trigger a CEL light, yet a few days later and much lighter driving i get this code.
TBH the spark plugs are getting changed this weekend, and i'll have a good cleanout with some carb cleaner. I will also adjust the throttle cable, and a new MAP sensor is on the way from HTG.
Does anyone else have any advice on steps i should take now that i have cleared the code ?
Old Jan 9, 2008 | 02:12 PM
MB's Avatar
MB
Member
Hi Armand.
I would wait and see if it returns.
It's not that common for a TPS to die, but wouldn't be the first.
The blip you had at 4k isn't unusual and can just be a hiccup, but could also be related to the TPS. The ECU uses the TPS to help with knowing how much fuel to add / control injector pulse etc.
Let us know if it does.
Old Jan 10, 2008 | 12:45 AM
Armand's Avatar
Thanks Mark,
Just one question though, should the part fail (however unlikely) is the sensor the same across all model years ?
I read that Honda dont sell this without the throttle body too, so likely to be expensive. Leads me to think i might have to try a breakers.
And whilst we're here, what about the injectors ?
Thanks Again
Ben
Old Jan 23, 2008 | 10:30 AM
Armand's Avatar
Ok just this evening i got the same code again P0122.
I have since the first code, cleaned the throttle body thoroughly, replaced the sparkies and checked for vacum leaks.
I would draw the conclusion then that the TPS is going to die on me shortly.
Anyone have an OEM throttle body, or a nice 70mm Spoon one going spare ?
Old Jan 23, 2008 | 10:46 AM
RedUn's Avatar
Taka Kaira seem to do Spoon throttle bodies cheap, might be worth checking out
Old Jan 23, 2008 | 10:56 AM
motogp1's Avatar
$434 plus delivery
Old Jan 23, 2008 | 11:25 AM
Armand's Avatar
Thanks guys, just been looking and delivery is likely to be
Old Jan 23, 2008 | 11:30 AM
motogp1's Avatar
[QUOTE=Armand,Jan 23 2008, 08:25 PM] Thanks guys, just been looking and delivery is likely to be
Old Jan 23, 2008 | 11:32 AM
Armand's Avatar
Awesome, thanks for your help i have sent them an enquiry.
What was the turn around like ? (in case the tps gives up the ghost before it arrives )
Old Jan 23, 2008 | 11:40 AM
motogp1's Avatar
really good just over a week i think .
