Swapping PreFacelift Headlights to Facelifted Ones - Harness for Auto Levelling
Hello Guys !
I'm actually swapping my LHD 00" Headlights with RHD 04" ones.
I have everything (complete set :ballasts, bulbs, LHD Shields), the only problem I encounter is that the plug of the 'auto levelling' is not the same.
Do you know if I can find a wiring adaptor for these ?
I assume I can skip this plug and manually adjust my headlights, but I like the work well done.
Facelift connector :
Pre Facelift connector :
Where are the guys who did the same modification ?
Just saw your post on Si@Hendy an you can get plugs that look remarkably similar to my untrained eye Toyota Lexus 3 Way Alternator connector housing plug 90980-11016 - LX10 | eBay
The part number seems to be 90980-10941 across many Japanese car brands
I previously swapped RHD facelift/AP2 headlights on my '05 car for a set that had been taken off an LHD car, and have just fitted them on an '02 car.
The plugs and sockets were all the same, no need for adapters either time.
It's probably so you cannot fit headlights that dip to the incorrect side easily.
Unless you have a multimeter and some crimp pins...
Try fitting conduite a droite - specific ones.
I'll order them and give it a try (I have a Toyota Dealership near my home)
