Performance Brake Pads
Old Nov 5, 2006 | 09:26 AM
lower's Avatar
Default Performance Brake Pads
Doing routine checks on my car today to make sure it is fit for Donington on Saturday, i whipped of a front wheel to check my brake pads. You can't check pad thickness easily on the fronts with the 17" wheels.
I put porterfield R4S pads on all round 7k miles ago and have done one trackday on them. Rears are fine, but the fronts are down to 1mm
so, i need new pads before saturday. I won't be able to get porterfields from the states in time, so does anyone have any recommendations for front pads that won't fade on the track that i can get in a couple of days. I've got a set of honda OEM pads that i can whack in if needs but, but they'll just fade on the track so i want something better.
I suppose ebc red stuff will be available, but are they any good? Any other suggestions of pads and suppliers would be appreciated.
Old Nov 5, 2006 | 09:50 AM
Pete Findlay's Avatar
I've just gone off Redstuff myself... just got one day at Oulton out of the last set, and the rears (rather than fronts ) are trashed. They're not kind to discs with heavy use, either.
I've just put some Ferodo DS2500 on for Donington, for a change. Had very good experience of them on the ITR, if a little dusty.
Got them here... rears, too...
Nice and speedy delivery
Old Nov 5, 2006 | 11:10 AM
nickrg3's Avatar
Which redstuffs Pete?
I have the new redstuff ceramics - work real well and seem to wear ok...?
camsport.co.uk if you want them lower. Phone him up get club price
Old Nov 5, 2006 | 11:48 AM
Fieldl's Avatar
Red Stuff Ceramic are pretty good I ran two sets of fronts with no problems.
Most motor factors should be able to get them next day.
Old Nov 5, 2006 | 12:15 PM
chilled's Avatar
Actually, OEM fronts with R4S rears works really well for me, although I'm going to be OEM all around for Donington.
Because the fronts fade, then the rears take a kicking, and because they're smaller, disintegrate quicker. But I had more longevity out of R4S rears and OEM fronts. The R4S don't really last on the fronts.
Old Nov 5, 2006 | 02:16 PM
Yep... Redstuff Ceramic. Used 'em for last season and most of this, too, apart from a brief excursion with a set of Porterfields as part of the group buy.
I got on pretty well with them, apart from the fact that they marked the discs pretty quickly. The front discs (Brakes Int) only lasted 12 months, scored and cracked. I get a couple of track days out of a set before the rears are well down - fronts only half worn-ish, which is different to what I expected. I never really felt any fade though.
I thought they were a cost-effective option, until I had to change the discs and added that into the equation. The new discs (EBC blanks this time) look like they are headed the same way too after one track-day, and I doubt that the rear pads would see out Donington.
I know DS2500s of old, although on a different car, so I'm going to see how they do on the S2000. These things are always going to be a compromise, balancing price, availability, pad wear, disc wear, dust, cold and hot performance etc etc.
Redstuff ticks a lot of those boxes, but I think it's the disc wear aspect that took me by surprise a bit - never suffered from it before with other cars / set-ups.
Old Nov 5, 2006 | 02:33 PM
m1bjr's Avatar
All the familiar issues with EBC that I read about on Scoobynet. I went down the Ds2500 road and they are far superior. Quieter and definately kinder to the rotors. Pagid Black is another option...
Old Nov 6, 2006 | 12:10 AM
Taikyu's Avatar
Banned
Spoon ?
Old Nov 6, 2006 | 12:30 AM
lower's Avatar
so that's two votes for the ferodo DS2500.
i see if i can get them in time.
Anyone got a supplier for the pagid blacks?
Old Nov 6, 2006 | 12:37 AM
Bibbs's Avatar
I've got EBC Red Stuff .. did 3 laps of Nur one after the other (went through the barrier on the main straight) and I was still impressed.
www.brakes4u.co.uk
