Polybush query
Old Nov 27, 2012 | 01:12 PM
RattyS2k's Avatar
Default Polybush query
At speed my S doesn't feel as planted as i feel it should do. i have been advised that the rear upper mounts have a small amount of play and may be the cause of the car feeling floaty light and pulling slightly to the left. Geo was done in the last 1000 miles.
It could also be the Avon tyres on the rear which i am running at 36psi. i will have a play with pressures to see if it makes any difference but the real question i want to ask is whether it is ok to just change the rear upper bushes for polybush ones, change all the wishbone bushes, change all the bushes on the rear of the car or save up and do the whole car.
If i did do the whole car would there then be any negative points with running standard suspension.
thanks,
Old Nov 27, 2012 | 01:21 PM
eSeM's Avatar
You should be fine if you do both of the rear upper wishbones. These are pretty easy to do from what I recall.
Old Nov 27, 2012 | 01:34 PM
RattyS2k's Avatar
sweet. will get them ordered to fit next week.
rickya
Mar 13, 2017 09:17 PM
Trunkz
Apr 24, 2015 01:03 AM
Fatbloke
Jan 28, 2011 10:34 AM
craigmatthews17
Jul 6, 2009 01:20 PM
stks2k
Oct 15, 2004 04:50 PM
