Powercables into the Boot Help!
Old Mar 3, 2009 | 03:28 AM
stu_c's Avatar
Default Powercables into the Boot Help!
Hi all
as one of my audio projects i need to get powercables into the boot whats the easiest place of getting it from the cabin into the boot?
Thanks
Old Mar 3, 2009 | 05:21 AM
tomkbucks's Avatar
there is a rubber grommit behind the fuse box on teh bulkhead that goes in to the passenger footwell - if you find the thread on under seat sub - i did a write up on an install and getting power in was something i mentioned - took pictures off
Old Mar 3, 2009 | 07:36 AM
stu_c's Avatar
Hi mate
Thanks for the reply unfortunatly I ment from inside the cabin into the boot
Cheets
Old Mar 3, 2009 | 07:43 AM
tomkbucks's Avatar
again you can take the pannel off behind the seat - 2 small screws behind the hooks , then feed the cable up the carpet and though here in to the boot - then remove the gubbins in the boot to find the cable
Old Mar 3, 2009 | 07:47 AM
S2000_FUN's Avatar
Maybe you can find some usefull info here
https://www.s2ki.com/forums/index.php?showtopic=295344
FISHWINTER
Euromeet 2009 - 10th Anniversary
Apr 6, 2009 11:50 AM
ByteIt
23
Jul 25, 2002 06:58 PM
