problem with washer jets :(
the headlight washers work fine, but when i push the stalk upwards for the windscreen washers, the window wipers go but no water sprays.
i opened the bonnet and tried to spray water again but there is no noise from the pump.
anyone know where the pump is located and is this a common problem?
is it gonna be expensive to fix?
Originally Posted by L600MEY,Dec 21 2008, 04:24 PM
if your looking at the front of the car look top left under the hood and there is like a lil flexi pipe bit make sure thats connected first also there could be a blockage i had it on the civic!
If it turns out to be the pump, that's located behind the offside wheel arch. Not a drama to change, just need to remove the wheel arch liner. If it's the fuse, the pump is probably the cause of the fuse blowing and may need changing anyway. IIRC, there is a Halfords one that looks and fits identically to the Honda part.
Good luck.
Good luck.
