Qube Engineering LED Dash
Old Mar 26, 2010 | 11:07 AM
jimmyb1978's Avatar
Default Qube Engineering LED Dash
https://www.s2ki.com/forums/index.ph...ic=688460&st=0
Only just spotted this post, has any UK members upgraded their dash through this sponsor or sourced a UK supplier?
(used the search but all of the results point to the original thread)
Old Mar 26, 2010 | 11:10 AM
The Loon's Avatar
Yes Squeak has. UncleFester has made his own
loftust's Avatar
https://www.s2ki.com/forums/index.php?showt...&#entry17940658
I got it direct from Qube, no other route to source one AFAIK.
Fester spent weeks doing a DIY job. Check out his ongoing modification thread if you fancy having a bash.
Old Mar 26, 2010 | 11:25 AM
jimmyb1978's Avatar
Thanks for that, think this may be my next mod!
Old Mar 26, 2010 | 11:56 AM
Garage R's Avatar
Just sorting details out with Art at Qube to be uk dealer if your not in a rush
Old Mar 26, 2010 | 12:02 PM
loftust's Avatar
Good man Rob
Old Mar 26, 2010 | 12:59 PM
Bramblecat's Avatar
Oh I'm very interested. Would you be doing the fitting as well Rob?
Old Mar 26, 2010 | 01:14 PM
loftust's Avatar
If Rob cannot do this (allow 5 hours for the first one ) and anyone needs advice fitting these, I'm more than happy to help.
I'll hopefully be fitting a white one to my own S later on this year
Old Mar 26, 2010 | 01:31 PM
Bramblecat's Avatar
Thanks Loftust. I'm shite with anything DIY. I'd probably end up with a burn't out shell if I attempted anything like this
Old Mar 26, 2010 | 01:33 PM
loftust's Avatar
It's also worth mentioning that your mileage is attached to your dash, so if you wish to retain your mileage, then you need this carried out on the instruments from your S.
However, IIRC, Kiwi knows someone who can 're-adjust' the mileage to what it should be on your S, but that would involve sending it away, and £££.
Alot of the work is concerned with the rear plastic housing, which is not specific to your car alone. Getting another set of instruments and prepping the white bit will save you some time and reduce stress, negating the need to take your S off the road for more time than necessary.
