Question about interior light
Okay so I know there are 2x 239 festoon bulbs in the interior light unit. Im wanting to change them to LEDs as I've seen various users (*ahem* Lovegroova *ahem*) with them and they look visually appealing. Having a look at eBay:
http://www.ebay.co.uk/itm/120906569149
My question is, would the size / dimensions of those fit? (Due to the bigger circuit board etc..) Or if someone can link me to some eBay ones that they have purchased and thus I know will fit etc.. would be very much appreciated.
Also, my S has now reached 106K. I've ordered a TCT from Billman as the missus is in new york at the moment and she will be bringing that back with her in a weeks time. Whilst changing the TCT, I'll also be changing the alternator belt with a gates item for peace of mind. I normally change the oil every 3000 miles (so thats approx. every 3 - 4 months) so castrol will be going in as well as part of the TCT fitting.
Apart from checking valve clearances which I will do when I take the rocker cover off to peel off the old paint and apply a fresh new coat at some point next month, what else should I be looking to do over the summer as part of servicing / maintenance; bearing in mind its age. A geo is on the cards as well; I had it checked by WiM a year ago and whilst they said it wasn't out; the bolts were stiff (or seized; the chap in question didn't want to find out) so will be attacking those over the summer as I have access to a ramp
Mine's the same year. Will add undersealing to the list; I really need to crack on and sort out geo though. Anything else comes to mind? AJ mentioned possibly the fuel filter sock, but those are meant to be a lifetime item; will probably change it when swapping out fuel pumps for the future turbo build.
s2konroids
Jan 26, 2010 04:10 AM
