Quick hardtop query!
Apologies if this has been covered before, but might have an opportunity to buy a hardtop in the next 2 hrs so just need a quick response - I've searched through old posts but am not completely clear. If this is a repost, can mods remove it then please?
I've been told the OEM hardtop includes brackets as pictured below, is this all I need to fit it to my car or are there any more parts to the 'fitting kit' which I need to get?
Many thanks
Gaz
Many thanks
Gaz
Gaz,
to fit the hardtop thats all you should need.
Just check your car to see if the bolts needed are already fitted. If not, any hardware shop will have them, make sure you cut them to correct length though, clearance is critical to allow the soft top to fold down safely.
Do you have the demister relay and pushbutton fitted??
CHEESEFRIES333
Jun 7, 2010 09:30 PM
Plastic Sith
Aug 31, 2008 02:01 AM
