Quick help needed
Old Apr 24, 2005 | 11:53 AM
Chris888jj's Avatar
Default Quick help needed
I'm having trouble starting the S2000, which I bought yesterday - haven't had any problems before.
It just won't start - after I turn the key and press the start button I just get a rapid ticking or clicking noise, with no hint of the engine trying to start. I've of course tried pressing the door opening indented button on the remote opener to activate the the start button, but it's not working.
Any suggestions? - I'd appreciate some help asap as the car is standed(with me) away from my house!
Thanks
Old Apr 24, 2005 | 11:56 AM
Putney's Avatar
sounds like a flat battery! I left my lights on for an hour and this did the same thing. RAC re started it with a big battery!
Old Apr 24, 2005 | 11:57 AM
Putney's Avatar
Old Apr 24, 2005 | 11:59 AM
Busamav's Avatar
as your in shite street ,
just take time to check the terminals to both the battery and the starter motor are tight and clean
Old Apr 24, 2005 | 12:23 PM
euan's Avatar
If the remote unlocking works OK, could be a flat fob battery.
Have you a spare, or can you get someone to take the spare keyfob to you?
The keyfob battery can be strong enough to unlock the car, but not deactivate the immobiliser.
Old Apr 24, 2005 | 12:32 PM
AquilaEagle's Avatar
Administrator
Do the dash lights go very dim when you try and start it?
is the starter motor actively turning?
Old Apr 24, 2005 | 12:35 PM
Chris888jj's Avatar
Thanks for the advice - my uncle is coming round with a set of jump leads...
Could well be the fob battery as well - but I've tried going in a quickly starting it which also doesn't work.
Old Apr 24, 2005 | 01:24 PM
Neil.H's Avatar
Keep us posted.
Old Apr 24, 2005 | 02:11 PM
Chris888jj's Avatar
Sorted! - the jump leads started it and I'm going to get a new battery tomorrow.
As I had just got the car and don't know a huge amount about the inner workings of a car I was thinking about all the possible things that could go wrong! - getting worried for no reason it turns out.
Thanks again to everyone.
Old Apr 24, 2005 | 09:44 PM
SilverShark's Avatar
it's not the best sound in the world when trying to start you car !!! - I had the same a while back & luckily it happened to me directly outside my Honda dealer !, I got a new battery and all OK.
Good luck !
