Quick tyre question
Old Feb 28, 2017 | 12:36 PM
mikefifth's Avatar
Default Quick tyre question
Hello.
current wheels: 8inch front, 9inch rear. Buying some tyres. Will 235 fit up front and 255 rear without rubbing? Car is slightly lower, not stupid.
purely track car, very minor road use.
I want as much grip as possible, current tyres are 225 40, 245 45. Will increase width from the above spec work?
mike
Old Feb 28, 2017 | 12:46 PM
Doyal's Avatar
Need to know the wheel offset really
Old Feb 28, 2017 | 12:52 PM
Chuck S's Avatar
Rear 255mm tires fit the OEM 17" wheels and standard car with no alterations. Aftermarket wheels or severely lowered and you're on your own. I run OEM 215mm on the front.
-- Chuck
Old Feb 28, 2017 | 12:53 PM
mikefifth's Avatar
embarrassing really, can't bloody remember!
99% sure: 48 front 50 rear
Old Feb 28, 2017 | 01:26 PM
MB's Avatar
MB
Member
What camber Mike?
If the fronts are +48 then you might have a slight rub, but only if very low and not much camber.
Mine are 8' +50 and my 235s rub slightly, but mine is mega low at the front ( tyre just below the arch)
Old Feb 28, 2017 | 01:33 PM
mikefifth's Avatar
Originally Posted by MB
What camber Mike?
225 it is. In all honesty I've never had any issue with 225 grip on the front end.....yet
thanks for the replies. Tyres ordered.
Old Mar 1, 2017 | 02:54 AM
MB's Avatar
MB
Member
You might a bit more if you put 255 on the back, but would have to be pretty in tune with it to notice.
Old Mar 1, 2017 | 03:17 AM
Fatbloke's Avatar
Have you not heard of the search function, Mike???
Old Mar 1, 2017 | 08:42 AM
Singh_snisen's Avatar
Most grip possible? Re71r, advan neova. Or rs3/4 for longevity.
Old Mar 1, 2017 | 11:43 AM
CynicG's Avatar
Should have tried Feds FZ-201 Mike. They look interesting...
