Rack spacer fitting
I'm going to fit the rack spacers I bought off Floppy months ago one day soon. I've read several comments about it being a bit of a pain to do, but access doesn't look too bad as I don't have the OEM air box in the way; am I kidding myself?
Also, does anything need removing, supporting, repositioning etc. and do the rack bolts need to be tightened to a specific torque, or just f'kin tight?
Any advice, hints and tips very welcome....
Cheers,
FB
Cheers,
FB
Nothing complex to this job other than good luck.
The only tip I can give you is to put the new bolts into the rack before you put the spacers in. Otherwise the crossmember interferes and you have to start again.
Also, slacken off your steering column UJ. This will make it miles easier
