Radar Detectors
Old Mar 18, 2002 | 06:24 AM
johnnyuk's Avatar
Default Radar Detectors
Anyone use them?
Been "saved" by them?
Recommended models?
I've never felt the need to have one - but now.......
Cheers!
John
Old Mar 18, 2002 | 06:54 AM
Leggy Blonde's Avatar
Hi John,
I've got a Snooper S5, which I bought off the net (slightly cheaper than Halfords etc). It is supposed to pick up Gatso's, mini-gatso's and hand held guns. The only think it can't detect is Digital speed cameras (thankfully a rare breed - at the moment!)
As far as whether it works or not, I can certainly tell you which camera's on the M25 have film in (or not). It will start to pick up a signal about 200m away or so from the camera which 'should' give you enough time to adjust your speed accordingly!
I don't know anyone else that has/uses a radar detector and this is the only one I've had so I've got nothing to compare it with - but it has saved me from several points!
The only annoying thing is it has a penchant for garage forecourts, Heathrow airport, and a 3 mile area in Liverpool - but as long as you can put up with the odd 'false alarm' I'd say it was a worthwhile investment.
Hope this helps
LB
Old Mar 18, 2002 | 07:11 AM
markcu's Avatar
Hi,
If you check out:-
www.ukspeedtraps.co.uk
there is a really good guide there, and there are some laser diffusers that work as well!
to be honest I think I sould get some to help avoid the "accident blackspots" where most devices are deployed.....
M.
Old Mar 18, 2002 | 07:51 AM
Frenchie's Avatar
I've had a RD for seceral years now (two different Uniden models). As Leggy Blonde says, it's a PIA with false alarms (trafiic lights and security systems in commercial buildings being the main culprits) so you have to be careful not to ignore warnings, just in case it's not a false alarm. Mine has saved me twice, once in Walsall in a 40 mph limit, big long wide main road - PC with a hairdryer halfway down, and once here in Shrewsbury. Again, as LB says, a RD also tells you which GATSO's are live and working.
I'm considering buying a laser diffuser and the Blue-i also. I should then be pretty well catered for.
Next step would be "chaff" and a missile system
Old Mar 18, 2002 | 07:53 AM
markcu's Avatar
Pete,
Couldn't you then use the blue-i to call in an airstrike from a nearby carrier?
M.
(currently bored at work)
Old Mar 18, 2002 | 07:56 AM
Frenchie's Avatar
me too. So much to do and no motivation. As it's my firm and I can do what I like, I'm going to p!ss off home now. It's still be here at 7:30 a.m. tomorrow.
Old Mar 18, 2002 | 07:58 AM
markcu's Avatar
Pete,
dont suppose you need a highly skilled, deeply motivated support manager in need of a challenge do you?
M.
Ps apologies for going off topic!
Old Mar 18, 2002 | 08:15 AM
cjtigger's Avatar
I have a Beltronics 990 international. It's super reliable and the only false alarms that I ever get are from garage forecourts. IMO it's a good piece of kit as long as you combine it with a keen general awareness of your surroundings.
Only downside is it's a nightmare on the restricted speed limit section of the M25 - the continuous beeping drives you mad! I usually switch it off as the traffic never generally goes above the legal limit anyway!
Old Mar 18, 2002 | 08:48 AM
andylong's Avatar
geodesy rocks
http://www.morpheous.co.uk
gps tracking combined with a database of every speed camera in the uk
wont protect you from pc plod at the side of the road - but that's what your eyes are for
origin thing is too big for my liking - the geodesy sits nicely on the dash above the engine start/audio controls
Old Mar 18, 2002 | 09:20 AM
Frenchie's Avatar
Pic available, Andy?
