Radiator problem?
Just been out in the S for the first time in ages since the big freeze hit the Midlands, and at the same time decided to fill her up, check oil and tyres etc.
However whilst cleaning out the enormous pile of leaves the S quite diligently seems to enjoy regularly hoovering up from Britain's roads, I noticed this (apologies for the crap pics - I lent someone my camera recently and haven't got it back):
Basically on the very front Heat Exchanger element (pretty much the first thing behind the splitter) the bottom lattice has come away from the next row up on the right hand side
It still appears fixed at the left but is hanging down slightly. I can only assme this happened when I hit a piece of debris on the road a few months back - I think it was a flattened can or something (the splitter avoided any damage but there was a bit of a whack).
I haven't noticed any issues since and whilst the coolant level is fairly low, it is not empty. It seems to be dry where the lattice has come away and it looks fairly minimal, however I'm obviously concerned about the damage.
Is this serious and how urgent is it to get this fixed? I'd rather not take it to Honda but would like to get it sorted before the next service.
I think my next step is to fill up the coolant and monitor it. What's the stuff to use and how much should you fill it up by (the indications on the bottle are absolutley crap!)?
Any other observations?
TIA
TIA
I've had plenty of cars with that and it has never been a problem. You can loose quite a lot of filaments and the things will work (on other cars anyway) I wouldn't be worried if I were you, just keep a weather eye on the temperature gauge to be sure.
Originally Posted by dennohue,Dec 29 2010, 07:34 AM
Have a look at the beginning of this thread!
Might be worth checking to see if the aircon works
Originally Posted by integra_man,Dec 29 2010, 06:13 PM
Thanks everyone. A/C works fine as far as I'm aware.
In my case, the problem was more advanced, and I decided it would be best to replace the air con radiator now, than to have to deal with the problem when I was on the road a long way from home!
