Ramps
Old Apr 13, 2006 | 03:12 PM
wampa's Avatar
Default Ramps
Hi guys, Will ramps work on the S. Just spent
Old Apr 13, 2006 | 03:38 PM
ade73's Avatar
No, and its too late now to spray your bushes.
Old Apr 13, 2006 | 03:42 PM
wampa's Avatar
according to chris aliment franklin never to late.
4 weeks of spraying give him a chance to free it!!
ok its a 2000 car!!!
I will let u know in four weeks if it works
Old Apr 13, 2006 | 10:06 PM
san2000's Avatar
wampster.....I planned to do this every week. Can I come and use your ramps?
Working today tho.
Old Apr 13, 2006 | 11:30 PM
aldfort's Avatar
Wampa,
Try to look before you leap. OK here is what you do
1) see if the ramps will go under the front of the car and touch the wheels BEFORE they touch the bodywork.
2) if yes - then you can try to drive the car onto the ramps. Have somebody watch to make sure the ramps don;t contact the body. If they do STOP immediatly and bin the ramps. Also watch back of car to see if exhaust is hitting the ground. If it is STOP immediatly and bin the ramps.
3) DON'T try to reverse up the RAMPS as it's almost certain that the front with touch the ground.
Old Apr 14, 2006 | 12:32 AM
Rteyp's Avatar
Step 1 - Jack-up car
Step 2 - Place ramp under wheels
Step 3 - Lower car onto ramp.
Make sure hand brake is on !
Easy - do it all the time and as safe as houses.
Old Apr 14, 2006 | 01:37 AM
baptistsan's Avatar
Doubt you will be able to drive the car up the ramps.
Do as Rteyp has said. Though I would advise using the central jacking point and putting the ramps under when the whole of the front or rear is in the air.
Don't do one side at a time imho.
Old Apr 14, 2006 | 02:37 AM
LTB's Avatar
LTB
Working today tho.
Just a thought San, but maybe would could start the SHSM a little earlier and get this done before we kick off.
I've got some axle stands so if you or Wamps has a half decent jack we'd have the makings of a SHSM (lube edition)
Old Apr 14, 2006 | 02:55 AM
wampa's Avatar
Right, Ramps do not fit under the front of the car but do at the rear.
Iam going to take the ramps back and buy a 2.5 tonne trolly jack.(is this good enough)
Where is the best point to jack up the car. I also have some axel stands for extra safety.
Old Apr 14, 2006 | 03:03 AM
LTB's Avatar
LTB
Wampa you have a PM.
