Rattle from cat possibly...
Old Mar 20, 2014 | 01:37 PM
Childsy's Avatar
Default Rattle from cat possibly...
Last few days I've noticed a rattle coming from under the car when rpm is around 3k. Sounds like a metallic rattle, pretty much the noise you would hear when the honeycomb inside the cat breaks down, so I will assume it is that! Will check where the rattle is exactly over the weekend.
Are there any other areas I can check for rattles?
If it is the cat can it be repaired? If not I'm looking for options. I will be getting an exhaust mod done this weekend so was thinking that a test pipe and exhaust mod would be too loud.... Has anyone on here got both done? Any vids? Would a test pipe effect fuel economy?
Are there any 3rd party cats you can buy that are as good as OEM? I see a few on eBay but unsure on quality...
Finally are high flow cats any good?
Cheers in advance
Old Mar 20, 2014 | 01:38 PM
unclefester's Avatar
Don't forget to check the heatshields around the cat and also in the engine bay.
Old Mar 20, 2014 | 01:40 PM
Childsy's Avatar
Will do, cheers
Old Mar 20, 2014 | 02:06 PM
MJK46's Avatar
I had a very similar problem recently. Turned out to be a bolt missing from the heat shield around the cat. New bolt in there and no more rattle, result!
Old Mar 20, 2014 | 02:43 PM
mattg4321's Avatar
Banned
Also had a couple of missing bolts from the cat heatshield causing this sort of noise.
Old Mar 20, 2014 | 02:48 PM
mikefifth's Avatar
Just get rid of the standard cat and get a high flow cat from berk or similar.
Old Mar 20, 2014 | 11:10 PM
WRCGooseS2K's Avatar
I had exactly the same mate when I had the original exhaust system on my car. it'll be that Childsy!
Old Mar 20, 2014 | 11:12 PM
Childsy's Avatar
Hoping it's just a missing bolt then! That would make life easier although I am toying with the idea of a HFC...... Hmmm
Old Mar 20, 2014 | 11:36 PM
cheshire_carper's Avatar
What exhaust do you have? I had an HKS fitted at one stage that made the heatshield type sound but it was the exhaust itself at fault.
Old Mar 21, 2014 | 02:08 AM
Childsy's Avatar
Only have an OEM exhaust
