Rear Plastic Window Replacement
Old Oct 27, 2004 | 12:31 AM
Raffe's Avatar
Default Rear Plastic Window Replacement
Is it possible to upgrade my misted up plastic window with the later spec glass one without changing the whole roof?
Or how complicated / expensive is it to just replace the plastic one and are there any companies you can recommend to do this job???
The only gripe with the new toy, other than that its awesome
Old Oct 27, 2004 | 12:33 AM
Lurking Lawyer's Avatar
Nope, it's a whole roof off job, I'm afraid.
StevenM has done it - he'll be able to give you an idea of the cost. I have a feeling he sourced the roof from a breaker and then had his dealer fit it for him.
Old Oct 27, 2004 | 12:41 AM
eSeM's Avatar
Replacing the plastic one costs ~
Old Oct 27, 2004 | 12:45 AM
Bassoctopus's Avatar
Have you tried the bmw cleaner referred to in the tech faq?
Old Oct 27, 2004 | 01:26 AM
Raffe's Avatar
Didn't realise it would be that expensive tbh!!
Thanks for the BMW window cleaner advice, will order some now and give that a go
Cheers.
Old Oct 27, 2004 | 01:43 AM
If it's just mist on the windsceen you will be amazed at the difference
Old Oct 27, 2004 | 04:47 AM
hondaboy2001's Avatar
Hi guys
I've just bought and used the Honda Screen Cleaner on my rear screen. I was only just able to see out of it before, and could barely make out what kind of car was behind me.
After having used the cleaner, I can now see clearly out of the rear. In fact, you'd be hard pressed to see any scratches at all from the rear view mirror! It's fantastic.
This screen cleaner is from Honda Motorcycles though, so the car guys had no idea about it. It cost
Old Oct 28, 2004 | 10:37 PM
952man's Avatar
I've just posted on the Tech forum on a similar thread - Hindsight from http://www.morethanpolish.com/mtp/ is recommended and is a sight ( excuse teh pun) cheaper than replacing teh screen. Its not cheap,
Old Oct 28, 2004 | 10:42 PM
BMW cleaner is about
Old Oct 29, 2004 | 12:57 AM
6500rpm's Avatar
I nearly gave myself a hernia trying to do the inside of my screen, gave up in the end
