Rear Shocks Recommendations
Old Aug 5, 2025 | 02:25 AM
Jakei98's Avatar
Default Rear Shocks Recommendations
Hello!
Recently bought and S2000 and fixed it after the previous owner crashed it. Trying to learn what I can in the meantime, after replacing headlight, various brackets, tie rod ends and the brakes.
Took it for the MOT and unfortunately it’s failed on rear shocks.
From a bit of research on the forum, new OEM seems impossible to get hold of, used OEM likely will have similar issues soon so looks like the move is to go aftermarket.
I think Koni’s are going to best for the budget (Ohlins would be preferable, but think we’ll have to save up for those…)
I’ve found a few sites that sell them, albeit some look a little different with the same part number and wonder which would be recommended? E.g: on the 2 links, there’s different ways to attach them
If anyone has any alternate links, or knows if it’d be worth paying extra for the Yellows instead, would be good to know
https://www.demon-tweeks.com/uk/koni-str-t-shock-absorber-kon8050-1150/
https://www.larkspeed.com/koni-strt-rear-shock-absorber-1386028/?aditem=1386028
Old Aug 6, 2025 | 12:28 PM
S2000_sam's Avatar
UK Moderator
You can pick up OEM shocks from some Jap sites but you need to know what you’re looking for. Your springs will be colour coded as per your car MY, every 2 years they were different . You need this and the shock part no which should be stamped on it.
Any of the coilovers you mentioned are certainly good enough.
Old Aug 6, 2025 | 03:07 PM
noodels's Avatar
Location uk?
Old Aug 6, 2025 | 10:06 PM
Nottm_S2's Avatar
A lot of people have swapped to koni shocks, that's the cheap solution
Swapping all for coilovers is a lot more expensive but a good solution. I wasn't aware you could get the (OEM) Showa shocks - that's a good solution too I think
Old Aug 6, 2025 | 11:55 PM
S2000_sam's Avatar
UK Moderator
I picked up a complete set of Type S suspension, only 3000kms for less than £1k home duty paid. As new.
Old Aug 7, 2025 | 12:00 AM
Jakei98's Avatar
Yeah I’m based in the UK, Northampton specifically
I committed to the Koni orange shocks, which for just the rate cost £120 each, and managed to get delivered next day. Interested to see how these feel once I fit them
That’s good to know OEM is still possible. I got a quote at the local Honda dealer and they could only source me one shock, which was £480.
Old Aug 7, 2025 | 12:02 AM
s2k4tony's Avatar
I have Yellow Speed Racing Dynamic Pro fully adjustable Coil overs, with 33 settings for hard / soft feel all done from the dial on the strut tower. Overkill I would say trying to dial in what you need, but I suppose it's to some people's taste. They were on the car when I bought it.
They're alright I suppose, about £900-£1000 a set depending where you buy. Bilstein do something similar and might be better quality, who knows, but are around £500 dearer.
If I was pushed, I'd stick with brand new OEM if they were available. I'd avoid used OEM, they are for the most part tired now and you're unlikely to find a used set with 50k miles on them or less. Most are pissing their seals But you're right - Ohlins might require a credit card as they are dear, but probably the best you'll get for the car.
Konis fine as said already
Old Aug 7, 2025 | 02:27 AM
lovegroova's Avatar
I loved my Bilstein PSS9s, though no idea what they cost these days.
Old Aug 7, 2025 | 05:39 AM
noodels's Avatar
May have to drill the top hats
Koni Yellow Sport Shocks - S2KI Honda S2000 Forums
Bettarn
Sep 29, 2013 08:56 AM
mrburtonsir
Jul 25, 2013 04:03 AM
Rob88
Jul 27, 2010 02:36 AM
tritium_pie
Dec 30, 2009 08:36 PM
dave.irl
Mar 25, 2009 11:01 AM
